Super A axle pivot shaft
Posted by Charles Green on September 01, 2013 at 09:01:14 from (71.209.10.3):
I'm reassembling the front end after replacing the steering box internals. The SA has the cast-iron front axle with the S shaped axle pivot that bolts to the bell housing. The steering housing's bolt pattern and locatng pins only allow its halves to go togather one way. The steering housing assembly bolts on to the engin with four bolts, period, can't go wrong there. The axle pivot shsft slides through the axle and into its bushings as it should but its bolt holes wind up about 1/4 inch too low in respect to their holes on the bell housing. Everything went togather as should, no binding, it all looks good. There isn't a 1/4 inch wiggle anywhere. Where can 1/4 inch misalignment come from?
