Re: Super A axle pivot shaft
Posted by Charles Green on September 01, 2013 at 15:28:00 from (71.209.10.3):
In Reply to: Super A axle pivot shaft posted by Charles Green on September 01, 2013 at 09:01:14:
I think I've solved it. I took the steering housing off, bolted the pivot on the bell housing and slid the housing onto it. I essentially assembled it in reverse. The weight of the housing was enough to flex the pivot so that the housing bolts lined up with their holes on the engin. This was only a dry run without the axle. I'm going to mount the axle in the housing on a wood dowel and see if I can make the dowel slide out as the pivot slides in.
