Check to see that all the cam lobes are the same height. Check the width of each cam at the shaft. The height minus the base circle is the lift. See how what you've got compares to the specs.
Keep the lifters in order in case you do not need to have the cam reground. If you have the cam reground, resurface the lifters. You might consider having the cam ground to Super M specs.
Like everyone else says, flatten out the lifter faces. Push rods should be straight. I like to keep them in order too.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
