Stuck C-184
Posted by Red Raider on November 30, 2000 at 15:04:00 from (192.105.235.146):
I don't know if my idea is hair brain or not. I've tried everything to free up three stuck pistons; MM, PBblaster, coke. What I'm thinking is to drop the pan, remove the rod caps, and drive the pistons up with a 5/8" rod grooved at the top so it rests centered on the piston pin. I may go with a hydraulic lift on the rod and let it set under pressure for a while. Has anybody tried this?
Post A Followup
: Re: Stuck C-184
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
