Re: can a bad kill switch cause intermitenent shut
Posted by gene bender on September 03, 2013 at 06:03:28 from (67.55.198.113):
In Reply to: can a bad kill switch cause intermitenent shut posted by ericlb on September 02, 2013 at 07:30:54:
Where is the sw mounted so that you put your foot on it to stop. Just disconnect the wire on the mag for the kill sw and see what happens then. Your new condenser mite also be the problem did the engine shut down before it was replaced same as now.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
