Re: can a bad kill switch cause intermitenent shut
Posted by ericlb on September 03, 2013 at 06:43:08 from (70.41.155.192):
In Reply to: Re: can a bad kill switch cause intermitenent shut posted by gene bender on September 03, 2013 at 06:03:28:
the original time it shut down the problem found was a cracked coil i think this was actually the factory coil on the tractor, it was replaced, at that time i decided that as long as i had the mag off and on the bench i would put in new points, condensor rotor cap wires and plugs so all that would be done as this is a working tractor, the new problem is it runs for a short time then shuts down, but it will refire and run again after a few minutes, to me, classic symtoms of a bad condensor, i put the original back in there as it was running before, no change thinking the bad coil may have also caused the original condensor to go out, i bought another new condensor and put it on, still the same problem, the first few times it quit i checked the fuel supply figuring the engine might be running out of gas, the lines are clear, and the carb has plenty og gas in the float bolw imeadatly after stopping so that cant be it, i just dont have any idea what is doing this other than bad, new parts, what next? do i get a whole rebuilt mag with a warranty? it cant be that hard to fix this simple old tractor
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong. ... [Read Article]
