Farmall 1066 cluncking sound in right rear axle area
Posted by farmallman1949 on September 03, 2013 at 14:12:20 from (70.195.65.236):
My 1066 started making a clunking sound in the right rear axle area when I was cutting hay. I disconnected the diff lock valve and cleaned and reinstalled it but it did not help. Today I disconnected the actuator line from the valve and capped it off so no oil was getting to the diff lock clutch and it is still making the noise. Could this just be a bearing or something bigger? And the Hyd. oil is full.
