International 460 fork lift
Posted by dirt fox on September 04, 2013 at 10:11:13 from (50.124.107.138):
Recently horse traded for a international 460 fork lift. It had a blown hose and I need a hint as to where to add oil for it. I see no external hyd tank , the pump appears to run off the transmission and I only see one large plug on the machine. So doe's one reservor run the trans and the fork lift or am I missing something here and what weight of oil would you use? Thanks for any help ahead of time.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
