Re: International 460 fork lift
Posted by RPM1941 on September 04, 2013 at 13:31:04 from (173.18.253.242):
In Reply to: International 460 fork lift posted by dirt fox on September 04, 2013 at 10:11:13:
I would guess without more info on the tractor that it is just a standard 460/560 hyd system that uses the rear frame as a reservoir. You can use any good hyd system oil, IH made their own called Hytran. The fill point was usually on top deck thru hole for shift lever after taking 3 bolts out for shift lever tower, most of them also had another cover next to shift tower that you could use also.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
