Re: D-282 Engine Question
Posted by pete 23 on September 07, 2013 at 12:03:09 from (74.47.41.165):
In Reply to: D-282 Engine Question posted by labman98 on September 07, 2013 at 07:53:50:
Over the years I have had many of those birds apart and the bearing clearance is always on the higher side of the book specs. Plastigage will give you some bad reading just by the temperature of the plastic and remember , different platigauge for different range of clearance. If checking mains from underneath, crankshaft has to be supported (pushed up) to get accurate readings. I prefer shim stock for accurate readings.
