Posted by kopeck on September 09, 2013 at 17:30:17 from (66.243.206.248):
Don't fix what isn't broken right?
So the throttle shaft in the Marvel on my BN is really worn, it still runs OK, not as good as it should have but better then you would expect with that much play. On the shelf I had a Zenith that was freshly rebuilt for a tractor that isn't ready for yet so I figured what the heck, let throw it on.
I bolted it on, syced it up (WOT trottle, WOT on carb, pin slides in freely) and fired her up.
Well, it idles nicely but anything over 1/2 throttle causes some massive surging. Not just a little hunting, like full range of RPM surging, non-stop.
At first I thought it was the carb but if I held the governor shaft steady it ran well.
To sync the carb I had to adjust the yoke on the rod a lot, it surprised me as I was doing it but I figured two different carbs...
I lengthened the rod back out to about where it was on the Marvel and it now doesn't surge but it's really the exact opposite of where it should be (the pin sides in when the carb and the throttle are at low idle). I didn't test governor response but I'm guessing it's not going to be great.
I didn't try the bump spring but isn't that more of a minor correction adjustment?
Everything is moving freely/not binding up.
K
This post was edited by kopeck at 17:32:26 09/09/13.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
