Posted by ShaneGreen on September 11, 2013 at 10:03:58 from (173.202.79.34):
Hi, Mowing along and my bush hog stops running. The PTO shaft has stopped spinning, but the clutch was still engaged. Tried disengaging, engaging it, but no luck. Removed the bush hog and shut it down. - the PTO shaft still has about 1/4" of play. - disengaged, it turns by hand with some resistance. - engaged you can turn it freely. - neither way feels like it used to when you were attaching an implement. - with the motor running, you can hear a change in the gearbox sound when you engage the lever. - clutch replaced about 3 years ago, maybe 100 hours on it.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
