Re: lousy spark on an M
Posted by oldtanker on September 11, 2013 at 12:10:20 from (66.228.255.116):
In Reply to: lousy spark on an M posted by P and R Pete on September 11, 2013 at 10:56:49:
OK, on that system you are supposed to have copper core wires, not the newer carbon core. Check the coil to see if it's a 6 volt (requires ballast resistor) or 12 volt external resistor required or a true 12 volt coil. Make sure the gap is correct on both the plugs and points and that the distributer has a good ground. All electrical connections clean, tight and bright.
Rick
