I don't know which type wires he has, I'll have to take a more critical look, but I do know they have a lot of resistance. He had a loose copper-core wire in his shed, and we put both meters on that, and there was no resistance at all.
But anyway, before I saw your posts, I went back up to his house and looked at the Champion D21s he put in, and the gaps were way too tight, so I re-gapped them to where they ought be. At the same time, I noticed his coil had the small wire from the positive coil terminal to the distributor, and believing it should be the negative side to the distributor, I swapped them around. After both fixes, it's running good. Funny thing is, I don't even know why it helped,
But I also need to see if it's a 12 volt coil, and whether it has an internal resistor or not, and get all this stuff right.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
