Yes. The third brush in the generator is probably adjustable. This adjustment limits the high charge rate. To put out moe voltage/current, set the adjustment closer to the fixed brush (closest to it). If still no joy, make sure the gen belt is tight enough (like a car belt) and the regular big fan belt is not way too loose (1.5inch deflection with hard thumb pushing is OK, less movement is OK to 1.25) too tight and waterpump bearings go out. A sure way to tell if the gen can put out enough (and if there is too much resistance in the Field wire going to the light switch or resistance in the light switch ground) is to ground the F terminal on the gen with a jumper, then start it and run it at 3/4 throttle. If it charges plenty then, replace the Field wire going to the switch with 12ga, and clean the connections and grouinding of the light switch, and the box, and the pedistal. Resistance in teh ground can be troublesome. When charging at 3/4 throttle into a charged battery, the voltage should be 7 to 7.2. Jim
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner.
... [Read Article]
Latest Ad:
[More Ads]
