Re: incorrect factory rear tire size, red flag?
Posted by Janicholson on September 12, 2013 at 14:10:07 from (199.17.6.25):
In Reply to: incorrect factory rear tire size, red flag? posted by pistons on September 12, 2013 at 11:29:08:
The gear ratio does change. This could cause a gear change to operate attachment correctly. The greater traction can also increase transmission loads as well. If loaded with ballast, or Iron, and if traction pulls the engine into maximum torque ranges in low gears, wear in excess of normal can happen. Duals on a tractor are far more problematic. Good sense and working the tractor inside of its design intent is operator driven, not because of tire choice. Jim
