Re: removing wear sleeve on H front wheel
Posted by pete 23 on September 13, 2013 at 20:18:42 from (74.47.41.165):
In Reply to: removing wear sleeve on H front wheel posted by bmagee on September 13, 2013 at 18:58:58:
I believe what you are referring to is the wear sleeve that is in the hub that the seal (which is pressed on the spindle) wears against when hub is installed. I just collapse them around the outer edge with a dull tool.(like an old broken screwdriver).
