Re: Hydraulics....
Posted by John G. Hasler on September 16, 2013 at 15:54:21 from (174.124.82.31):
In Reply to: Re: Hydraulics.... posted by D Slater on September 16, 2013 at 10:28:09:
> When he moves the valve to lower he is dead
> heading the pressure and some is leaking by the
> spool when it does that and causing a pressure
> raise on the lift line and 3 point.
But when he does that he is also connecting the lift line to the return so the leakage should not be able to develop any pressure in the lift line: the leakage should just flow down the return.
