Posted by D Slater on September 16, 2013 at 10:28:09 from (184.14.177.70):
In Reply to: Hydraulics.... posted by John M on September 16, 2013 at 03:25:30:
If the hose on left in picture is pressure from the pump? Right one return to reservoir? Top rear to lift cylinder? Top front hose blocked? Front hose blocked is the problem. It needs to dump back to reservoir or tee into the return line on the right of valve. When he moves the valve to lower he is dead heading the pressure and some is leaking by the spool when it does that and causing a pressure raise on the lift line and 3 point.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
