Posted by FBH44 on September 18, 2013 at 01:13:36 from (64.85.214.131):
In Reply to: Setting Carb on 48H posted by Farmallb on September 17, 2013 at 08:46:28:
You mentioned "both" screws. There"s three. The idle speed screw is the small one at the top of the carb, facing outboard. I"m gonna post my procedure again, may help. Adjust all three screws. Make sure the float isn’t sticking or touching the insides of the float chamber. Some previous advice was to use a Dremel tool and smooth the insides of the float chamber so it doesn’t rub or touch. Pretty important. Set the float so the top of it rests 1 27/32" above the flat surface of the float chamber. Initial settings are as follows to get it started; Main fuel adjusting screw, big screw facing down at an angle, towards the rear, at the bottom of the carb; 2 1/2 to 3 turns open. This main screw turns clock-wise for leaner mixture. [This screw adjusts fuel.] Idle air-mixture screw, smaller screw facing forwards, on upper left-hand side of carb; 1 to 1 1/2 turns open. This idle screw turns counter-clockwise for leaner. [This screw adjusts air.] Idle speed screw, faces outboard, at the top of the carb; set for 450 rpm, and make sure the governor correctly engages the slot. [This screw adjusts RPM’s.] Final settings are determined as follows; Get the engine warmed up, and idling. Turn OUT the idle air-mixture screw until rough running, then turn in until it idles smooth. (Mine is set at 1 turn open.) Rev it up, wide open, warmed up, then turn the main fuel adjusting screw IN until rough, then out til smooth, then 1/4 turn to 1/2 turn further out. (Mine sits at 1 turn open. Other advice has been to set it at 2 1/2 turns open for pulling implements.) Should rev up smoothly and evenly. Too Lean = stumble, sputter, damaged melted plugs. Correct = tan plugs. Too Rich = back smoke, black sooty plugs.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
