Re: Setting Carb on 48H
Posted by Farmallb on September 19, 2013 at 07:21:54 from (97.73.64.150):
In Reply to: Re: Setting Carb on 48H posted by FBH44 on September 18, 2013 at 01:13:36:
Sorry. Forgot to mention there is NO screw facing the outside. Just the one under the govenor tube, and the one on the lower bottom opposite side. I have it set as per your instructions, but found that ith the one under the tube, if I ran it all the way inside it idled a bit lower. Don't know about its pulling power yet tho,
