Re: Loud left final drive gear or Transmission 130 Farmall 1
Posted by Hendrik on September 19, 2013 at 07:21:59 from (193.30.192.187):
In Reply to: Re: Loud left final drive gear or Transmission 130 Farmall 1 posted by William catalina on September 19, 2013 at 07:15:17:
These are standard single row ball bearings. No matter how frugal one is, a worn ball bearing can only be replaced by new.
If you run the tractor with badly worn axle bearings you may damage the bull gear and the gear on the differential shaft.
HTH, Hendrik
