Re: 1949 Farmall - H...Hydraulic oil leak...need some advice
Posted by Raner on September 19, 2013 at 18:02:27 from (173.175.94.231):
In Reply to: 1949 Farmall - H...Hydraulic oil leak...need some advice... posted by Raner on September 19, 2013 at 12:30:15:
Thanks Anthony...
That cleared up what is what perfectly...
I was messing around in my tool box and found a
seal for a 7 1/4 or 8 1/4 Dodge rear end pinion seal (Can't tell it's been to many years since I turned wrenches at a dealership but it's one or the other do know that for sure)
I had the coupler out so I checked the ID of the seal and it's
a real good snug fit so tomorrow I will check the OD and see
it will work...I just may luck out if the OD is the same will see...
One more thing what kind (off the rack fluid can I use to fill
the unit back up....The one in there sure looks like power steering fluid Chrysler uses...Thanks again for taking the time to help me out...Raner...
This post was edited by Raner at 03:35:26 09/20/13 2 times.
