Re: 1949 Farmall - H...Hydraulic oil leak...need some advice
Posted by Janicholson on September 19, 2013 at 19:24:45 from (74.60.94.18):
In Reply to: Re: 1949 Farmall - H...Hydraulic oil leak...need some advice posted by Raner on September 19, 2013 at 18:02:27:
The fluid might be almost anything. The fluid is supposed to be non detergent 30 wt for summer, and non detergent 20 wt for winter. If you share implements with newer tractors use what they use. Hytran fluid, or JD Hydraulic Transmission Fluid is just fine to use as well. Jim
