Re: electical question
Posted by jdemaris on September 21, 2013 at 17:06:47 from (70.192.13.104):
In Reply to: electical question posted by rosedale123 on September 21, 2013 at 16:43:44:
A fully charged battery with NO alternator charge is 12.7 volts. If the alternator is working, the voltage should be 13.8 to 14.2 volts. So yes, your alternator is not charging. You can bypass the voltage regulator if you want by sticking a pin in the back of the alternator into the "full field" port. If it starts to charge, it means the regulator is bad (A $12 item).
