Re: Farmall M Electrical
Posted by Patrick HMD on September 22, 2013 at 01:24:44 from (75.0.234.33):
In Reply to: Farmall M Electrical posted by Phil Pidgeon on September 21, 2013 at 22:04:16:
Hi Phil. sounds about like mine when it first arrived, a total mess. But the guy managed to start it with his 12 volt battery from his chevy silverado, to unload it. He drove it in the shop, and there it sat till I got it all squared away. More $$. Went and bought a heavy cranking amp 6 volt battery, made some new battery cables from some welding lead, rewired everything correctly, and she fired right up.
Here is the schematic you want to use if you have a magneto ignition. This of course is for a delco gen. Not sure how different they are from the lucus. You'll also notice that it has a cut-out and not a regulator.
[URL=http://s313.photobucket.com/user/bib44wcf/media/farmall60_zps29061e65.gif.html]third party image[/URL]
I got my wiring harness from these people. They do good work.
http://www.wiringharnesses.com/
Regards
Patrick
'49M
This post was edited by Patrick HMD at 01:38:21 09/22/13 2 times.
