Posted by Janicholson on September 22, 2013 at 09:09:23 from (74.60.94.18):
In Reply to: Farmall M Electrical posted by Phil Pidgeon on September 21, 2013 at 22:04:16:
With a Lucas system and Lucas light switch it is beyond our direct input. The attached diagrams might help some, but liberal interpretation is needed on the switch and Lucas system. The 46 vintage would have the system described in the diagram previously supplied, (no regulator) To go to US original, you will need: A light switch (4 position -LHDB- Low charge High Charge, Dim lights, Bright lights. A cutout relay for the generator, and the generator. Probably a belt and brackets for the gen as well. If you want US all the way you might aldo need light fixtures.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
