Re: 6v starter for WD9?
Posted by nebken on September 22, 2013 at 16:48:34 from (64.147.41.33):
In Reply to: 6v starter for WD9? posted by nebken on September 22, 2013 at 12:20:16:
The numbers on the tag are 1108920 and 17043
I found the 1108920 number in my valu-bilt catalog. it says W9,WD9 WR9,and WDR9. It is listed under 6v starters.
There is also a WD9 starter listed under 12v with different numbers.
Did Ih use both 6 and 12v starters on the WD9 or this starter just for the W9 gas?
