Re: 6v starter for WD9?
Posted by Red Mercury on September 22, 2013 at 21:28:41 from (204.112.53.120):
In Reply to: Re: 6v starter for WD9? posted by nebken on September 22, 2013 at 16:48:34:
I just checked an IH parts manual and 1108920 is a starter was used on the W-9 and WR-9. As far as I know, all WD-9's are 12 volt. The aftermarket catalogues occasionally have errors in them--best to use IH's parts manuals for this stuff.
Also, WD-9's & W-9's don't use the same engine block. Similar, but not the same.
