Re: Farmall M Electrical
Posted by SadFarmall on September 23, 2013 at 05:59:57 from (112.213.155.53):
In Reply to: Farmall M Electrical posted by Phil Pidgeon on September 21, 2013 at 22:04:16:
G'day, SadFarmall here. If you need the full Lucas diagram, with pictures, I have a Farmall AM Parts Catalogue. You should note, however, that (usually) if you have Delco starter, the tractor should also have a Delco generator. I have the Lucas catalogue and diagrams of everything you need for a Lucas set up. Beware of the generator mounting brackets! The mounting bracket and belt adjusting arm for the Lucas generator will NOT work for Delco-Remy or vice versa. You should be able to e-mail me through modern view and I will send you what information I have. The loom is easy. I just bought the wire for mine and made it up. Can make one for you if you like, heaps of wire left over.
Cheers,
SadFarmall
This post was edited by SadFarmall at 06:01:52 09/23/13.
