Re: Cub Farmall Throw out bearing question
Posted by Farmallb on September 24, 2013 at 09:08:39 from (97.73.64.147):
In Reply to: Re: Cub Farmall Throw out bearing question posted by Denny ('60 Lo-Boy) on September 24, 2013 at 08:32:31:
(The bearing slides back and forth over the top of the shaft). OVER THE T O P OF THE SHAFT??? What does that mean. I think the bearing has to center all AROUND the shaft.
What/Where is the graphite surface??
It has NO grease zerk.
