Re: Cub Farmall Throw out bearing question
Posted by mkirsch on September 24, 2013 at 11:39:19 from (64.80.110.74):
In Reply to: Cub Farmall Throw out bearing question posted by Farmallb on September 24, 2013 at 08:25:39:
The shaft is NOT supposed to "grab" the bearing.
The bearing does not rotate.
A Cub throwout bearing looks like this:
http://www.external_link/new/cl/378fp.htm
The gray surface in the first image is the graphite.
If you have anything different you have the WRONG bearing. There are some aftermarket ball bearings, but they do not last long.
