Re: Cub Farmall Throw out bearing question
Posted by Farmallb on September 24, 2013 at 12:35:17 from (97.73.64.147):
In Reply to: Re: Cub Farmall Throw out bearing question posted by mkirsch on September 24, 2013 at 11:39:19:
Your site didn't open. The bearing has 2 studs that fit in the brackets that hold those studs. The center hole is 1 1/4in dia. The shaft is 1in dia.
