Re: coil getting to hot!!!
Posted by RB on December 03, 2000 at 05:50:18 from (4.54.19.4):
In Reply to: coil getting to hot!!! posted by ranparr on December 02, 2000 at 03:56:37:
Sounds like you have two problems.Forget he resistor deal and get a 12 volt coil with a built in resisitor.That should fix that,then replace the condensor.Should fix you right up.
Post A Followup
: Re: Re: coil getting to hot!!!
