coil getting to hot!!!
Posted by ranparr on December 02, 2000 at 03:56:37 from (205.188.198.32):
I have a 49 H 12 volt system.I've had to replace the coil twice.I put a voltage reducer inline seems to help alittle but still gets to hot after a couple of hours of use.Also on cold start-up I have to use a jumper wire on the voltage reducer to get enough spark. Cranks okay after that as long as coil is not to hot. Thanks for any help.
Post A Followup
: Re: coil getting to hot!!!
