Re: Draw bar receiver hitch
Posted by DeltaRed on September 27, 2013 at 07:53:21 from (97.118.25.192):
In Reply to: Draw bar receiver hitch posted by 62champ on September 27, 2013 at 05:22:28:
I reread uour post...I extended the drawbar on our
SC to pull a rake with.I bolted a 2' long 3/4x2
1/2 flat iron to the existing drawbar.ThenI
installed some diagonal supports.There are two
3/4" bolt holes at the top rear of the rear
housing.Bolt a strap from there down to about 6"
from the end of the extention.A little
'fabrication' will be required.'nother thing...You
mention a 2 5/16 ball,those are usually reserved
for the biggest/heaviest trailers.A SC is a small
tractor.Make sure the trailer is not too much for
the tractor to handle....
