Re: Draw bar receiver hitch
Posted by 62champ on September 27, 2013 at 08:17:20 from (68.238.207.3):
In Reply to: Draw bar receiver hitch posted by DeltaRed on September 27, 2013 at 07:53:21:
The only intended use for this is to move empty trailers. That is why I would like to have something with a receiver on it so the ball size could be changed with the pull of a pin.
Thanks for the help.
