If it has to go in more to make room for something like a seal then you will need to use something like a socket, a piece of pipe, a piece of tubing, solid rod, etc. to press it in further. Choose something that catches as much of the bushing as possible but is slightly smaller than the casting itself (You do not want your pusher press fitting into the casting). Sometimes you have to custom make something - especially on thin wall bushings. Scrap piles sometimes come in handy for projects like this, but I always start looking at my socket sets if I can.
On one thin wall yet large in diameter bearing; I was forced to remove a few thousands by free handing with a handheld grinder on the old bearing race so I could then use the old bearing to push in the new bearing (remove only enough material so the pusher no longer press fits into your casting). Of course less creativity, improvising, scrounging is required if you have access to a lathe. With a lathe any pusher can be accurately made in any exact diameter that you need.
If the bushing is already in the proper place within the casting yet the grease hole does not line up then all you can do now is drill a new hole in the bushing for the grease hole. Unless you think you can easily remove it and reline it up (which as hard as it sounds like it went in - I doubt you could remove it without damage).
This post was edited by rankrank1 at 09:23:19 09/27/13 5 times.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
