Posted by Ellis Kinney on September 27, 2013 at 08:26:41 from (74.139.97.108):
I had quite a time getting the lower steering bushing out of the bolster. Buggered up the inside of the casting, dressed down with the die grinder. All OK. Problem is getting the lower bushing all the way in. I used a bottle jack and a block of wood to press it most of the way in, at times the bushing would take the weight of the entire front end and I would hammer on the bolster so it would drop about 1/8 inch, repeat. Is this normal? The bushing needs to go in about another 3/8 of an inch for the hole to line up for the grease fitting, but IT IS FLUSH WITH THE BOTTOM OF THE BOLSTER. What should I do now???? Thanks, Ellis
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
