Re: Draw bar receiver hitch
Posted by Haas on September 27, 2013 at 17:15:36 from (50.142.111.41):
In Reply to: Draw bar receiver hitch posted by 62champ on September 27, 2013 at 05:22:28:
Go to a store (northern tool?) that sells hitches and towing
equipment. They will have 2x2 receiver tubes of varying
lengths. Get a longer one and drill two holes that match the
holes in the C drawbar. Place the holes so the bolts don't
interfere with inserting the hitch device. Then just bolt the
hitch receiver to the C drawbar. Probably best to use 3/4 inch
bolts. My experience with this, the C gets light on the front if
you have much of a load on your trailer. It will be OK for
moving empty trailers.
