Re: Draw bar receiver hitch
Posted by 62champ on September 27, 2013 at 18:55:46 from (68.238.207.3):
In Reply to: Draw bar receiver hitch posted by Haas on September 27, 2013 at 17:15:36:
Exactly what I ended up doing. Friend across the road has a BA drill press we will use on Monday.
Weight will not be a problem if I mount the middle busters on the old SC...
third party image
Thanks
