Re: Troubles adding hydraulics to an M
Posted by mkirsch on September 30, 2013 at 05:00:17 from (64.80.110.74):
In Reply to: Troubles adding hydraulics to an M posted by hiperdart on September 29, 2013 at 15:38:47:
The way it's hooked up, all you're doing is circulating the oil in the reservoir. You're sucking it out of the front drain and pumping it back into the rear drain.
I don't know how it could have possibly worked like that on another tractor.
Luckily the fix is rather simple. Just connect the hose coming out of the pump with the 45 degree fitting to the hose that is coming out the side of the tractor.
