Re: IH 300U Torque Amp
Posted by mkirsch on October 01, 2013 at 12:00:26 from (64.80.110.75):
In Reply to: IH 300U Torque Amp posted by 4020guy on September 30, 2013 at 14:56:22:
Independent PTO has a second drive shaft that runs below the transmission and rear end to drive the PTO unit at the rear. It is powered off the clutch pressure plate by a "tube gear" that runs on the outside of the transmission input shaft.
Transmission-driven PTO just pulls the power off the transmission input shaft at the rear.
If you have the transmission-driven PTO, your tractor is lacking the second shaft and all the associated parts.
