Re: coil getting to hot!!!
Posted by Jamie Fay on December 03, 2000 at 18:47:56 from (24.218.208.40):
In Reply to: coil getting to hot!!! posted by ranparr on December 02, 2000 at 03:56:37:
make sure you have the leads on the coil connected properly, if they are reversed it will still work, but overheat. If you originally had a positive ground and changed to negative with the 12V, this may be your problem as the leads to the coil need to be reversed.
Post A Followup
: Re: Re: coil getting to hot!!!
