Farmall A - 1940
Posted by oldiron on October 05, 2013 at 16:30:08 from (69.245.136.49):
Hello
I just inherited a 1940 Farmall A, with a cultivator, snow blade and disc.
I'm tickled by this new arrival, and am curious what belly type mowers are designed to hook up to this machine, either from Woods or IH.
Currently, the rear pulley is the wide belt type (not v-belt) but I suspect that can be changed pretty easily.
Also, I have the curved tine type cultivator, and was curious which manual or book I need to figure out how to install and use the cultivator.
Thank you so much in advance for your patience...
I am a Massey/Ford guy, so this is a new direction for me... (Massey 30, Massey 101 Jr, and Ford 3400)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
