Re: Farmall A - 1940
Posted by gene bender on October 06, 2013 at 02:23:49 from (207.177.56.89):
In Reply to: Farmall A - 1940 posted by oldiron on October 05, 2013 at 16:30:08:
The curved tools are an option as they can be replaces wth regular shanks with shovels. If it has a pipe frame where the curved tooling fastens you have a A-136. If it has only one lever for lifting mounted on top of the tranny its an A 134. The other model and most common its an A-138. The 136-138 can also be exhaust lift attachments that attachment will have two levers the same length. A woods 6ft belley mower would be fine they also have a 5ft model.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
