Re: F20 Clutch Pedal - rebush / replace mounting stud
Posted by robgIN on October 07, 2013 at 19:47:40 from (76.208.19.178):
In Reply to: F20 Clutch Pedal - rebush / replace mounting stud posted by doehmke on October 07, 2013 at 19:10:12:
all you have to do is remove the little bolt that holds the clutch pedal shaft in and remove shaft and pedal together. Nothing to it.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
