Re: F20 Clutch Pedal - rebush / replace mounting stud
Posted by pistons on October 08, 2013 at 11:39:30 from (67.52.234.226):
In Reply to: Re: F20 Clutch Pedal - rebush / replace mounting stud posted by robgIN on October 07, 2013 at 19:47:40:
Are you describing my F20 or yours? ha ha. Mine has a similar sloppy clutch pedal that veers left, can't go right because luckily it hits the frame. Just a cotter pin and a washer. Sheered it off once, lucky was trying to put in gear and not taking it out! That was a 10 cent breakdown. My thoughts are to weld another rail on the left side of the clutch pedal, so its caged in on either side to remove all side slop.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
