Posted by Super-H-Mike on October 10, 2013 at 07:41:37 from (76.164.147.173):
Is there a way to figure out where the anti-freeze thats getting into the oil is coming from on an assembled engine ? I cant seem to think of any way. Cylinder leak test and the like tell you that there is a problem, but not the source. I am thinking, pull the head, check for cracks and straightness, see if gasket shows sign of failure, and if all looks fine there, go further. If you pull the pan, do you think you could see if the sleeve seal was leaking with pressure applied ? Other ideas ? Thanks
