Posted by Owen Aaland on October 10, 2013 at 17:37:32 from (216.47.34.210):
In Reply to: D-360 posted by Cyrus T on October 10, 2013 at 01:26:15:
If the return line goes to the top of the tank it should have no restriction. If the return line enters the bottom of the tank there most likely is a check valve which you most likely can not blow through. Take the fuel cap off to make sure the vents are not plugged.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
